440 Source Head Opinions?
based on that screenshot, the PP 240 heads were 60HP better than the 906 heads and peak HP was the same RPM.
that is on a mild build too.
that seems pretty good. I'd also wonder if these were some pristine example 906 heads that came out of Dulcich's stash or something too. I know they do recycle alot of parts and builds to keep the content rolling out consistently...
It's been a while since I watched the episode but I want to say they were a pair of heads Dulcich had in his stash that he did a light amount of work on. Like light bowl/casting flash cleanup, decent valve job etc.
So if they were 516 would that not bump the compression up ?
Plus did the 440 source have a decent valve job ?
Not really the best comparison.
Stock combustion chamber on 516 heads is 84ccs. 915s are about 79ccs and Stealths are around 80cc
I think the Stealths were just untouched OOTB. My local race engine builder/machinist (Atlas Performance in Loveland, CO) has messed with those heads before, he said with a GOOD valve job (factory one kinda sucks) and valve heads back-cut it'll pick up 20+ cfm in the lower lift ranges especially just off the seat. Just what I need for a torquey truck engine that'll see towing duty with a very mild cam that only has ~.430" lift.
So in a nutshell regarding the Engine Masters test... factory iron heads were ported and flowed more than stock, Stealths were untouched but could've benefited from a valve job, and the Trick Flows were a tad too big for the engine to make good use of. IMO that explains the lower-than-expected HP increases for each head type.
They weren't ported, magnafluxed, they did have some minor valve work done, and four new valves. That's why the price was $350. I can get the specifics so you can scrutinize further,
I'd do a set of iron heads if they were that cheap. Think I'll call my local machine shop and see what they say for rates.
Guess I'm jumping in too quickly lol, I was just going off what @1968rt said.
I'd do them if they were that cheap too, have a pair of 346 castings but they're original high-mileage pieces so they need basically everything... valve seats, guides, likely new valves, springs, retainers, locks, cleanup deck mill. And I'd still have open-chamber iron heads that flow significantly less than the ported Edelbrocks on my SBM 360, fer cryin' out loud lol.
Rebuilt Non-906/452 Heads from Aerohead start at $499.
That’s with bronze guides, SS valves, and HP springs.
906/452’s are $200 more.
But if you add hardened exhaust seats, 2.14/1.81 valves, and the bowls ported and gasket matched...... you’re at $1137($1337 for 906/452).
Pretty easy to get up into the Stealth price range.
I had arrowheads on my 413 before the stealth swap, the stealth heads are so much better imo.
Check out the Sidewinder Mopar heads from Marsh Performance
Nope, no more money being spent on my car.
Lol you say that now haha.
i wasn’t pointing to anyone in particular, just saying that I hear good things about Todd Marsh and his sidewinder heads for Big Blocks. The price is comparable to 440Source and he’ll custom build them with whatever you want. In hindsight, I wish I’d gone with those vs my Edelbrock RPMs.
12.40s is good enough for me, cheaper to run less stuff potentially breaking.
Stealth heads with the seats recut and a nice bowl blend with flow right about [email protected] lift.
Most home ported stock heads(especially 906’s and 915’s) I’ve tested are typically in the 250 and less range.
The [email protected] is a little more than these flowed:
On my bench an ootb TF240 flows right about 316/[email protected], and 320/[email protected] lift.
I’ve tested about a dozen of them, they’ve all been within a few cfm.
Exactly what I got with my TF, OOTB was 318, cleaned up the CNC ribs, removed practically all the turbulance and went up to 324. Great heads
Alright you guys talked me into it, mine are off now.
