Thanks to all who helped with my header/spark plug issue, very helpful. The engine in my `71 Duster is a stock (except for a 750 Holley dominator and aftermarket manifold) externally balanced 440 from a truck. Has an "F" on the plate on the front of the block so I guess it`s 1969 vintage (?). Anyone familiar with this? Is it one of the low compression versions? Low deck hight? Haven`t had it very long, no money spent on it yet and looking into what I can do with it. Would be happy forever w/ 400, 500 max HP out of it. Has a 3:55 rear w/ 8 & 3/4" gear, stock Torqueflite (not sure which model), MT street slicks, mini-tubed rear, 6-point cage. Willing to spend some $$$ on it (heads, cam, ?) if reasonable results can be expected. Will the B&M Flexplate #10237 solve the rear balancing issue? Have a 2500 stall converter ready to go in, def want to replace the stock balanced converter that`s in it - very low stall. Have the stupid weld-on counterweights if I need them...Motor sounds good but def mild. Should I just save up for a new mill? This car mostly for street/show maybe Street Night in Epping NH someday..... Thanks in advance.
