No you will need to order the intake for the low deck motor (383,400) as all head dimensions are the same for the big blocks no matter what they came off of. Also you will need the headers off the low deck engine also but i guess i should mention this is all assuming your building the 451 with a 400 block and 440 crank and not just boring a 440. Which i would assume you are but just making sure so im not mixing you up Good Luck Justin
