I have two 489 housings, and am trying to identify them if possible. One is a 3.23 open that came with some extra parts and im fairly sure its the original to my 9-70 built 71 R/T charger. It has a date of 12-23-69 on the ring gear. The housing casting numbers are clear, but the date is not as good. It has two codes, one is 000 and the other appears to be 344 or 844. The second housing is much harder to read the casting numbers and has aftermarket 3.55 richmond gears. It has only one code and appears to be 319 or 819 that is very hard to read.
