I am working on building a 489 center seciton with 3.55 gears and a new Eaton Posi. This is the first time I have tried to rebuild one of these so I am taking my time and learning ALOT.
I am working on sitting the pinion depth and have ran in to a couple of issues. The first time I pressed the large pinion bearing on I re-used the .034 shim from the 3.23 gears that came out of this housing. They were waaaaay to deep.
So, I pressed the bearing off and switched to a .024 shim. When I re-assembled it I couldn't get the backlash under .035. I had to take a break for a couple of days.
I came back to it last night and tried to figure out why I couldn't get the backlash set. What I found was that the case on the posi unit was butted up against the inside of the differential housing. In the 3rd and 4th picture you can see where it rubbed as I was rotating the ring gear.
The first thing I did was make sure my caps were on the correct sides. I marked them before I started this project. I know for a fact that they are on the sides that they belong on.
The gears are new (from Doctor Dif) Strange/US 3.55s.
At first I was tempted to pull the posi unit and chamfer the edge of the housing. But, I wanted to ask around before I started widdeling way on stuff.
Has anyone ran in to this before? How should I go about fixing this?
