4bbl to 2bbl plate for 4bbl air cleaner
Speedway mtrs (a mile from me,I used to work there) has a metal one for ~$20 but I'm hoping this one will suffice
I used to buy a lot of parts from Speedway , back when I was building ratrods
The aluminum ones are much better. Don't waste your money on the plastic ones. They warp and then you may as well not even run a filter. You would be surprised at how fast your cylinder bores will wear out if you don't have a good seal on the filter.
