[SOLD] 4L60E to Big Block Bellhousing
Tsully
The United State of South Carolina!!!
4l60E to Mopar Big Block Bellhousing. It has never been ran on the street, I did fire the engine up but the headers started leaking water around the exhaust bolts and after 2 try’s with different heads, I decided to just go back with a small block with stock manifolds.
This was part of the Silver Sport Transmission Stage 3 A41 Kit that I bought.
This is for the Aluminum Bellhousing and starter adapter only that is designed for A bodies. The only mods I had to do to the trans tunnel was bend the pichweld at the firewall and cut 1 1/4” out of the tunnel bracket, other than that, nothing else. I can send the instructions to whoever buys it.
Located in Saint George SC 29477 asking $350 shipped.
Any questions just ask!
So what else does a guy need to use this in an A body other than the obvious tranny and converter? Thanks. Kim
It has to be the 4l60e trans as it has the removable bellhousing, its the same as a 700r4 only electronic controlled and the 700 doesn't have the removable BH.
It will depend on whether your motor is internally or externally balanced as to which flexplate you use. Mine was a 69 383 so mine has no weights and I'm able to use it with my Magnum 318 I'm going back with.
When I got the Kit, it came with a different crossmember that had be made to fit the A body and trans mount. I can take a picture for you of it with the old one side by side so you can see what would needed to be modded to make on original member work.
The flexplate is an 130 tooth RM947 by Quicktime for internally and the converter is 298MM for a 700r4 or the 4l60e.
The drive shaft will have to be modded due to the chevy output shaft and Mopar rear.
