Well, it was supposed to have 4.56 Sure Grip with the shortened tubes and upgraded axles. Was out taking pictures and working on stuff and decided to double-check the gear ratio. Definitely over 5 turns to 1 rotation of the axle. So I guess I need to do more research on transmission ratios and figure out exactly what I want to do.
Top speed would be 116mph at 6,500 RPMs, 3,500-4,000 RPMs at highway speeds.
What that means as far as I can tell, is if I want to drive highway at all, I will have to have an OD A-833. (160mph max speed at 6,500 RPMs, 2,500-3,000 at highway speeds.)
