streetdak
I posted this on another forum, but figured I'd try FABO also, any help would be awesome!
I've been doing a magnum 5.9 swap in a 73 dodge dart. And I am having issues getting spark. So let me give as much information as I can to see if anyone can give me a hand.
I had a complete donor vehicle
to work with, a 98 Grand Cherokee 5.9 Limited. Reared and interior is trashed, so it made for a perfect donor vehicle. This motor ran like a top and I fired it up the day I pulled the motor. I pulled the motor out and mated it to my 904 trans. As for the wiring, I of course used the entire engine harness with the black and white PCM connectors that is basically 100% independent of the Power Distribution Block. I cut wires at both sides of the firewall and then removed the power distribution box and grey harness side.
I now have the motor in the car
, the harness (black/white) installed and even the power distribution center and harness (grey) hooked to my PCM. All the grounds are in place, alternator is hooked up. I am using my Dart's starter relay and wiring so that I did not have to modify the wiring since I moved the battery to the trunk.
Now, I have not hard wired the car, I have been working with the harness to make sure I got spark before I routed wires and lengthened anything. Here is what i do have. At this time I have not bothered with an ignition hot, I have just routed everything to a constant battery + and connect the battery to test as If I were turning on the ignition switch. I know that most of the stuff in the power
distribution is not utilized such as the horn, high beams and so forth, so I have not bothered any of those circuits.
Right now, I do not have the fuel
pump (on green/white) ran to the fuel pump, but I do have all the ignition on (orange) wires from the ASD/FUEL and PCM ran to the constant power, I also have the blue/grey wired to the constant power at this time. When I hook up the bat, confirming with a test light both the ASD and the Fuel Pump relays cycle for 3 seconds and the cut off. So I know the PCM is grounding the circuits upon ignition. But When I go to start the car I am receiving no spark. Injectors seem to be cycling, as I hear them and they also have power when battery is hooked up.
Upon the swap, I never messed with the crank sensor I don't think that there should be any reason to be bad as well as the cam sensor. This motor fired about 6 months ago without any issues. I think it has to do with my wiring. Does any one have any idea what I missing? I know when I first started I bypassed the ASD by grounding the pink/white wire and I would get constant hot at the coil, but no spark. I think it has to be something that I just don't have right.
More notes, O2 sensor is plugged in, trans wires and 4x4
are still attached to the harness, but not hooked to anything besides the neutral safety switch is grounded (black/white). Not sure any of this matters, but the more info the better. Also, I have not hooked up a comm port or a "check engine light" yet but will be doing that on Monday. I really think I'm close, not sure where I went wrong, any help is appreciated!
