moparmaniacduster
Active Member
$1500 firm. Located in Amherst, NH.
Perfect drivetrain swap for an old mopar. Was going to use this in a 70 Duster but sold off my project (no time at this point in my life).
5.7 Hemi
- From 2003 Ram 1500 w/ 116k miles. I heard it run myself before being pulled. Very quiet and great oil pressure.
- Complete from throttle body to oil pan including coil packs, plug wires, exhaust manifolds, all accessories, etc.
- Comes with complete engine side harness with ECU
- Comes with factory gas pedal/cable setup for DBW (2003-only option)
- Note it does have a few broken valve cover bolts and exhaust manifold bolts (very common issue). Need to be drilled out and heli-coiled.
A518 2wd
- A518 3 wire version with lockup converter (only made for two years)
- comes with stock pan and dipstick as well as stock truck lockup converter
- can also provide a 4wd non lockup A518 for extra parts if wanted
Note: Engine comes with stock pan/dipstick and no motor mounts. Picture is older from when I had the milodon pan and Schumacher mounts on it.
5.7 Hemi
A518 2wd
