Mopar Sam
Well Fed Member
This is an ‘03 5.7 Hemi that has been bored And stroked to 395 cubic inches. Has Callies Compstar 4340 crank and H beam rods, Mahle pistons, Comp 268 Hyd.Roller, 92mm throttle body, Accel injectors, Hooker B-body swap headers. This is a very nice, streetable Motor, perfect for a daily driver. Will work great with a mild converter. It will also come with the MSD Hemi ignition controller.
It is currently in a car, so you can hear it run. It has less than 4000 miles on it. Asking $9500.
Located in 62899
If you want the EZ EFI system and/or the 904 transmission with RMVB with the motor, I will make a good deal on them.
We are only selling to help fund a new shop building.
Located in 62899
