[FOR SALE] $5 Garage SALE! All items $5 each.Can combine shipping!
gregpurcell
Greg Purcell
Near Savannah, GA
Cleaning out the garage getting ready for the FMA show in Ocala this weekend. Here's the first table full of $5 each stuff. Scroll to the bottom! I keep adding more!
OK so far. we've got a body steering column holdup brackets, a length of defrost hose, rubber shift fork boot, two body tow hooks from a 66-70 B body, miscellaneous shifter boots & cover rings, slant 6 balancer & AC lower and water pump pulleys from late 60's early 70's A body, miscellaneous carb adaptors and spacers, 73 up spool type 318 motor mounts (no inserts), 73 up A body transmission mount with exhaust hanger, 73 up A body inner door handle cups, small block distributor holddowns, big and small block coil brackets, "V8" emblem with studs, insignia emblem (tape on), 66-67 Plymouth Fury AC plate, Certicard holder with all the mounting studs intact(embossed writing faded off) ALL $5 EACH plus the ride!
OH! The white bucket seats are from a 74 Dodge Colt but they can be mounted into anything. I can't ship but they will be at the FMA show this weekend for $30 PAIR!
OK so we have sales pending on the distributor hold downs, the small block coil bracket, and the shift fork boot. 2of the steering column brackets are sold.
Also another sale pending on the defroster hose.
Here's some MORE stuff: I have 5 brake proportioning valves (some people just call them T blocks) They are for A/B body with drum brakes. 4 have been cleaned and polished, one has not. A STEAL at $5 each! Window washer manual foot pump, truck/van oil filler cap, several battery box legs, a 66-70 B body gas pedal. studs good some rubber separation on the bottom. AND a good set of stock used big block rocker arms & shaft. One bolt is missing, rockers are pulloffs and need cleaned but they are not badly egg shaped. $5 each ($10 pair) plus the ride.
Sale pending on van oil filler. 6 cyl balancer & pulley sold, still have one set of /6 ac pulleys
Here's some more stuff to add to the pile:
We have a vacuum pod for mid 70's A body,2 more rubber shift fork boots, a big block 4 groove lower pulley, 2 more neutral safety switch wires, An electronic scale control (scale died controller still good),console wiring harness for b/e body (lights up PRNDL plate),set of 4 k frame bolts for $5, A body gas cap year unknown, big and small block oil slinger, A body fuel filler trunk floor gasket ALL $5 Each!
OK! today we add some emblems to the mix!
I have the individual D A R T letters from a late 60's car. One stud on the "A" is gone ($5 for all 4), a very nice "Belvedere II" Glove box door emblem from a 66-67, "Duster", "Plymouth" two flat "DART" emblems ( one broken but repairable) and the inside door emblem from a 71-72 DEMON. $5 each plus the ride or take all for $20 plus the ride)
would u do $20 Shipped for all the emblems ? 96750
I had two sets of twin pulleys (ac & PS I think) I believe they were both sold at the last swap meet. I'll look tomorrow. Thanks!
I have one water pump pulley left for slant six. It is the 2 groove ac pulley. I don't remember if the PS was driven off the AC or off the crankshaft pulley.
Hope this helps
Hope this helps
PS is driven by a pulley bolted to the radiator side of the harmonic balancer
