[SOLD] 500 cu in Big block, Brand new engine
jrlegacy23
68 Barracuda
Laurens, NY
500 Cu in Big Block (400 block), Freshly machined, internally balanced, and painted Hemi Orange, never assembled. Engine is ready to be assembled. Bored .033" over.
4.15" 440Source stroker crank
KB forged pistons with full floating pins
Eagle H-Beam RB rods, with ARP Bolts
440source Aluminum heads
ARP Head Bolts
Complete Felpro gasket set
Hughes Performance Roller cam
Coated cam bearings, installed
Brass distributor drive gear
Mallory Unilite distributor (used)
Milidon 7+1 Oil pan
Milidon 1/2" pick up tube
Torker 383 Intake (used)
Crower roller lifters (used)
Melling High Volume oil pump
Polished Stainless steel shorty headers
ProForm 1.5:1 roller rockers with chrome moly shafts (used)
Billet rocker shaft hold down kit
3/8" Chrome moly ball/cup pushrods
440Source neutral balanced chrome harmonic balancer fluid damper
Total seal, file fitted chrome moly piston rings
Tri-Metal rod and main bearings
Billet aluminum valley hold down bars
Neutral balanced 440source flexplate
Cloyes Hex-a-just True Double roller timing chain
Billet fuel pump block-off plate
I believe I have just about everything needed for completion except the Carb, valve covers, and some smaller nickle/dime stuff.
PM me here for more info or email me at jrlegacy23 @ yahoo. com without the spaces. I am located near Cooperstown, NY 13326
I am asking $6,000 or best reasonable offer. Pick up only, but will meet you somewhere for a non refundable deposit based on the distance that I have to drive. Will consider partial to whole trades for small block depending on setup.
Here is a pic of the head set on the painted block and one of the headers:
attachment.php
attachment.php
..........I got some sb parts if ur interested in some kind of a trade.......i dont need the heads and some other stuff................kim.............
I am looking to sell the complete package. I am putting it together little by little each day. If I complete it prior to selling it, I am going to put it in my Dart.
