71-440-Duster
Brand new 512 Stroker kit for 400 block from 440 source. Has optional light weight crankshaft. Comes with 400 block, rod bearings, piston rings $2600
Piston part number 5067 you can check specs on the following link.
Platinum Series Pistons - 4.375 -12 Dished-440 Source
Brand new CnCd 440 source stealth heads $1700
Stroker Kits-440 Source
Stealth Aluminum CNC Cylinder Heads - ASSEMBLED SINGLE HEAD-440 Source
I’m east of Marysville California.
