My 516 heads on my 1966 383 2bbl (converted to 4bbl) needs a rebuild and here in Sweden there aren't that many cylider heads to choose from but I've found a couple of aluminium heads here that cost approx the same that it will cost to rebuid the 516.
I've read that the 516 head have combustion camber anywhere between 73-79cc and the aluminium heads I've found have 84cc.
I'm not looking for a high revving engine, I prefere low end torque and I'm worried about the 84cc would loose too much compression and that I loose low end torque with them.
Please help me do deside if I should go for a rebuild or buy the 84cc aluminium heads.
I'm from Sweden and I apologize if my English isn't correct.
