rustytoolss Well-Known Member Joined Sep 26, 2013 Messages 972 Reaction score 73 Location Clinton, Ohio Mar 11, 2020 #1 Will the overdrive unit from a 1996 518RE / fit and work if bolted to a 1990 A500RH ?
rbkt65 FABO Gold Member FABO Gold Member Joined Dec 25, 2017 Messages 2,201 Reaction score 1,592 Location jerseyville, illinois. Mar 11, 2020 #2 probably bolt up but re trans are engaged differently. if yours is bad, there are several places on internet that sell rebuilt o/d units only.
Max1196 FABO Gold Member FABO Gold Member Joined May 12, 2016 Messages 1,537 Reaction score 1,711 Location Swift Current SK Mar 11, 2020 #3 There is two metal tubes that extend to the output shaft section in the "RH" models that transfer fluids to the governor devise, there isn't a governor on the tail shaft of the "RE" model!
plumkrazee70 Well-Known Member Joined May 5, 2013 Messages 3,762 Reaction score 1,467 Location Medford, Oregon Mar 11, 2020 #4 rustytoolss said: Will the overdrive unit from a 1996 518RE / fit and work if bolted to a 1990 A500RH ? Click to expand... RE is electronically controlled. You'd have to get the 518 RH or 618 (behind diesels.)
rustytoolss Well-Known Member Joined Sep 26, 2013 Messages 972 Reaction score 73 Location Clinton, Ohio Mar 11, 2020 #5 Thanks guys just save me a bunch of $$ and work.
