.528 Solid Small Block Cam Specs
Jofis
Isanti Minnesota
Does anyone have a cam card or recall the intake centerline specs on this mopar cam? Not the lobe separation......that I know is 112 degrees.
Also anyone have a set of the mopar aluminum rockers laying around in the 1.6 ratio??
Do you like it better than the original 106 LSA
I've never run the .528 with a 106LSA. I ran the .528 cam as far back as 1998 and I only remember the 112 LSA version from MPP.
THat cam would be nasty af with a 106lsa. NOt my flavor for a LA street engine, but nasty for sure
I ask because this is the cam that's going in my 340 sixpac 4speed it will be my first solid lift, considered many other sticks but I landed on this one when it became available New old stock. Mopar performance oval track.I just realized this may not have been the original grind but a variation for oval track use.
Tat makes sense for oval track. Tight LSA power band works great on an oval, fast accel, hard off corners, race gas.
dang, lookit that p4529968 cam, 509 lift and 280 duration on 108 LSA, if their duration @.050 method is accurate it'd be about 238@.050, probably a really sweet little solid lifter cam there...
