lxmodguy
Gen3 Hemi Guru
I have a freshly built 6.1 based 426 hemi. It has about a $4000 rotating assembly in it. Head studs and main studs, cometic gaskets, high lift johnson lifters, CNC ported eagle heads. All top-notch parts went into building it. Driver-friendly cam, should make 650+ easily and drive anywhere you want. 11:1 static compression will run on pump gas. Long block, no intake or exhaust. Timing cover is included.
About 12k into it. $10,000 firm can take it. Its $450 to put it on a pallet and ship it. No Alaska or Hawaii shipping.
