[WANTED] /6 225 oil dipstick. 1966 Dart
3spd6
Active Member
san diego
Rating - 0%
0   0   0
Looking for the correct dipstick for my /6. The original was eaten by the crank.. found lots of little pieces in the bottom of the oil pan when we rebuilt the motor. The one that came with the car when purchased is too short to provide an oil level reading.
Picked up a replacement from a Dodge truck with a /6 but that did not work.. the stick was too long. Does anyone have one they can part with that will fit a '66. In San Diego, CA.
Cheers
Greg
Cheers
Greg
Hey Greg,
I have one from a 65 Dart /6 170. Will that work for your? Let me know...Old Dart 66
Old Dart. I have one that is on its way. I will be in touch if the problem does not get solved.
Cheers
Cheers
By the way, did the new speedo I sent for your 66 work out. Thanks. OD66
OD66
Have not had the chance to tear into the Dart. Hopefully next weekend. I will let you know how it goes.
Thanks for the heads up, like I said, I have the dipstick for the 170, and I do not know if that will work for you. Thanks.
Old Dart 66
