6 cyl K frame
'67 and up A body
will be correct for '73 and up because of the spool mounts.
A decent part thought to swap into an earlier car if sticking with a /6 but you would also need the proper lca and sway bar because the '67-'72 sway bar will not work. Also a decent idea if going with bbp.
