66plyValiant
1986 dodge ram, has 225 /6 with a carter 2 barrel carburator, when I got it ran rough and had lean burn, done complete tune up including new cap, rotor button, plugs wires and non lean burn distributor.
had miss at idle before doing anything; runs alot smoother now but still has a miss, like a plug only getting fire every other time, pulling 19" of vacuum steady, doesn't seem to have any vaccum leaks; haven't done compression check. also idles high, turned idle screws out and it still idles way to high (1000-1100 RPM)
rebuilt the carburator it did have a little dirt in the right side jet but after cleaning and rebuilding it still runs the same with the same miss and high idle
