/6 to 360ci swap
jeff66
I am sure there is at least one thread on this somewhere, just can't find it.
I am pretty sure I know what I need. The only question I have, as I have read so many conflicting articles is the internal / external balancing subject.
Now, I have the 360 with the 360 converter. Is this all I need? Or do I need one of the flex plates the like summit sell for the conversion?
Thanx.
Jeff
273-318-340 are internally balanced. 360 is externally balanced. If you are using a 360 balanced converter, then you are ok. I always just balance a flex plate (about 50 bucks), then I can use the converters that I use with 318's and 340's.
you just need the matching weighted 360 converter. the balanced flexplate is for non weighted converters to use with the 360
**treed**
If you have the proper 360 converter, you don't need the special flex plate.
If you have a 340 converter for a 360, then you need the special flex plate....
