For sale is a Clutch/Brake assembly that I media blasted, painted and reassembled with new bushings. Comes with a manual brake push rod and mounting bolt and nut, and the over center spring, along with all the mounting bolt. As pictured these will fit 61-66 A-bodies. If you need them for a 67-76, I can change out the main body with the one pictured and you wind up with a 67-76 set of pedals. The later arrangement comes with the brake light switch and bracket, the lower steering column support bracket and the upper brace to the body, also the manual brake push rod and nut and bolt . Also the over center spring along with all the mount bolts. $275.00 plus shipping.
