[WANTED] '62 Plymouth Valiant std shift column
wittenbn
Member
Rating - 0%
0   0   0
Wanted a 1962 Plymouth Valiant standard shift steering column. Must be complete. Do not need the steering wheel or steering shaft. I think '60-'62 the same. Send photo if possible. Thanks
Will help with your search. As a 62 valiant owner I know how difficult finding parts may be. Good luck
What column are you looking for ? The 1960 used a different gear box ,The 1960 and 1961 stick cars had the shifter on the floor .The 1962 had the stick lever on the column .Anyway I have a 1961 valiant parts car it is a automatic trans car it is a standard steering car if this helps let me know.
Need a steering column for a manual trans. Thanks
Car belongs to a friend. For now he has hopefully repaired the inner manual trans shift column
by cutting and welding a good upper section from a later column. Will see if it works OK
try 63-66 cars ,the 3 on the tree should be the same in those years as a 62, 60-61 use a different diameter steering shaft.
62 was the precursor to the 63-66 a body line virtually all suspension is the same.
Lawrence
the biggest difference is Power steering Vs Non/PS one
