63/64 dart stone guard trim clips
Dartnewbie
Former Dart owner
I got a beautiful set of stone guards from Waggin and it seems there is a place for a trim clip about midway up the guard that would pull the body side of the guard tight. It has a slotted opening which I assume is for some sort of clip to hold the guard to the body other than the 3 screws that attach it to the wheel well and at the bottom. Does anyone have a picture of how these are attached? Could probably find the clip if I knew what I was looking for.
Duuuhhh You gotta go to the source LoL,I thought you had the clips so I left the holder unclipped for you to install the screw type clips,pm me and I'll give you my phone # and walk you thru it,I didn't have the factory clips as someone had mangled them off of a car and I ended up with them. =)
