[WANTED] 63-66 speedo cable, clutch fork bracket.
Rockerdude
Rock n' Roll and A-bodies
Arizona
I need a couple things to finish my four speed setup in the wagon, I need the clutch fork bracket that bolts to the inside of the bell housing for an a833OD (the larger bracket) and a 63-65 speedo cable. PM me if you have either items. Thank you!!
The bolt pattern for the bracket looks like this.
I might have a speedo cable-- 66 won't work -- it changes to the push in style-- 60-65 are the style you need, Lawrence
. . . .inside of the bell housing for an a833OD (the larger bracket) and a 63-66 speedo cable. PM me if you have either items. Thank you!!
Sounds like you are using the OD 4 speed. If so, you'll want the 66-67 style speedo cable. The 65 and earlier cable is unique to the 65-earlier transmissions.
Sent from my iphone
No, Im using an early style 65 trans with an OD Bell housing. Thank you though for clearing it up.
I knew that, sorry I was in a hurry posting this last night.
I have the od pivot...pms me with e male and I'll send you pix.
mike bee
Still need the 63-65 Speedo cable and OD clutch pivot for the bell housing.
Update: Bought a speedo cable, still need a clutch fork bracket for a a833-Overdrive bell housing!
Speedo Cable arrived, still really need a clutch pivot!!!
I measured the two holes for the pivot and center to center they are 4 inches apart. Still need a pivot!
