[SOLD] 63-72 Upper Control Arms
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Got a set of 63-72 upper control arms with the small ball joint that I was going to use with a 65 Valiant (now parted out). These have been blasted, POR-15'd and top coated with black paint. They've had new bushings installed as well as new ball joints installed and torqued to specs. Ready to install on your 63-72 A Body with either 9 or 10 drum brake spindles or Kelsey Hays disc spindles (don't forget to grease the ball joints!). $100 plus shipping from 22657.
No interest in these? After installing, add grease and go! Fits up up through 72 all spindles and maybe 73-76 with the SBP stuff.
What brand of bushings and ball joints???
Thanks for the inquiry. I did these about 3 years ago to use on a 65 Valiant (now long gone). I've still got 2 boxes of Moog sway bar bushings for when I get to that point so I believe the replacement parts were Moog I bought off eBay.
