Hideogumperjr
My headlight adjusting will not stay in adjustment. I found that the headlight wiring was stuck between the headlamp itself and the bracket (for lack of a better description) that holds the lamp and is used to adjust the beam.
The plastic piece that the headlight beam adjusting screw goes into is cracked because the stuck wire kept the lamp from adjusting correctly.
Anybody know where I might get a replacement plastic piece or the 63 Dart?
Thanks
John
Thanks
John
