TAK65
The case in a nutshell; speedometer started making noises and the odometer got stuck in between 6999 and 7000, took the cable out, inspected (ok) and lubed. Stayed quiet for a day, then the noise started again, odometer not working anymore. Then the needle got wild and broke off.
There is a working unit from a 65 Valiant I can have for nothing.
Does anyone know for sure if these speedos interchange? Of course, I will see when I pull the cluster but it'd make things easier if I knew beforehand.
Any insight would be appreciated
