[WANTED] '63 Valiant wagon tailgate torsion bar
shortmort37
Upper Darby, PA
Rating - 0%
0   0   0
Mine is missing. I have the slotted panel that bolts to the right side of the body, but I need the torsion bar itself (and perhaps, retaining hardware - I've yet to remove my panel to see what remnants I've got in there).
adTHANKSvance,
Dan
You could fabricate one. But as far as keeping the torsion, you might need a springy steel. Someone good with steel/welding could
better advise you. Mine was broken. I'll check to see if I welded it together, or had to add a new end.
