Driver Ed
Member
Hello, All- Came back from a drive and my top would not raise. It worked fine an hour earlier. Lack of motor noise told me it was electrical. As I had rebuilt the motor a few months back, I suspected the switch. I removed the switch, cleaned the contacts and it worked again. But, I don't really think that was the cause(I've seen worse connections work). Anyone else have experience with such a sudden failure? The wiring diagram in the FSM shows there is a circuit breaker, but does not detail where that lives-or what would trip it. I read on another post later switches had the circuit breaker on the switch, but mine does not. My switch is a chrome knob that hangs below the dash which you rotate to the left or right to raise or lower the top.
Thank you for any help you can offer.
Driver Ed
Driver Ed
