64 dart front blinker housing removal?
Early A-Body Discussions
  1. cmac64dart
    cmac64dart FABO Gold Member FABO Gold Member
    322
    77
    May 31, 2015
    mays landing nj
    Local Time:
    2:40 PM
    I am removing my engine wire harness prepping for a front frame rail replacement. How do you separate the bulb socket from the blinker housing on the front valence. I seem to remember them being just pushed in but I don't want to force it. There is some rust in there. so maybe its just rusted together. Thanks in advance, Chris
    • Like Like x 1
    • slantsixdan
      slantsixdan =..=
      6,537
      1680
      Jan 7, 2007
      Vancouver BC
      Local Time:
      11:40 AM
      You don't. The socket is integral to the housing. The parts are (front to back): Chrome bezel, lens, lens gasket, bulb, housing-socket-cable assembly.
      Interchange (parts or whole assembly): '61-'62 Lancer, '63 Valiant, '63-'64 Dart.
      • Like Like x 1
      • Nigel Hely
        Nigel Hely 64DartDownUnder FABO Gold Member
        221
        98
        Sep 13, 2016
        Blue Mountains, Australia
        Local Time:
        4:40 AM
        It's pretty easy, just go carefully if it's rusty (spray some WD-40 or something first).
        1. Remove the two screws holding the chrome bezel which retains the lens.
        2. Remove the bezel, the lens will stick to the gasket, carefully prise this apart.
        3. The bulb socket is attached to valance panel with 2 (or 3, I can't remember) self tapping screws, remove those.
        4. The bulb socket should lift straight out, or prise carefully with screwdriver.
        • Thanks! Thanks! x 1
        • cmac64dart
          322
          77
          May 31, 2015
          mays landing nj
          Local Time:
          2:40 PM
          Thanks for your input guys, slant six Dan got me thinking. When I got home from work I followed the wire up into the harness and proof there is a connector . I'm still not sure how I missed it but thanks again,
          • Like Like x 1
          • Agree Agree x 1
          • slantsixdan
            slantsixdan =..=
            6,537
            1680
            Jan 7, 2007
            Vancouver BC
            Local Time:
            11:40 AM
            Yes, there's a connector that unplugs. That wasn't the question you asked, though. :)
          • cmac64dart
            322
            77
            May 31, 2015
            mays landing nj
            Local Time:
            2:40 PM
            Yes, it's not the first time I spoke/wrote my own gibberish. When you said it doesn't come apart it kind of got the wheels turning though. Are these available anywhere? Or is it my usual early a goose chase. I wouldn't mind replacing both blinker housings with all the rust in there
            • Like Like x 1
            • Nigel Hely
              221
              98
              Sep 13, 2016
              Local Time:
              4:40 AM
              Yeah, that's it. Located in the engine bay just above those big rubber grommets on the front of the inner mudguard panel, next to the radiator support panel. Same deal for headlights, they just unplug...
              • Nigel Hely
                221
                98
                Sep 13, 2016
                Local Time:
                4:40 AM
                I would not be surprised if they are used on something else. Perhaps not with that exact same lens and bezel, but the housing/socket part maybe...
              • cmac64dart
                322
                77
                May 31, 2015
                mays landing nj
                Local Time:
                2:40 PM
                My harness was replaced at some point and the person who did it had jacketing over it . That's why I didn't see the connector at first. As far as the parts they all work , the housing is a little rusty though
              • slantsixdan
                slantsixdan =..=
                6,537
                1680
                Jan 7, 2007
                Vancouver BC
                Local Time:
                11:40 AM
                Optically the rust doesn't matter; there is no reflector bowl behind the bulb -- the optics are all in the lens. If the socket spring/contact plate are old and crusty, fix with parts described in this post.
                • Like Like x 1
                • cmac64dart
                  322
                  77
                  May 31, 2015
                  mays landing nj
                  Local Time:
                  2:40 PM
                  Thanks , a super useful thread. As normal I am impressed.You truly are a mopar encyclopedia
