[SOLD] 64 Dart GT
WRB426
Insane 4 Mopars
MA
I'm selling my 64 Dart Gt. It was built as a drag car but I have most all the parts that I pulled from it. So it could be put on the road again. Car runs good except starting to have oil going by the rings. Compression is still 170 across the board. The car has 110 runs on it.
Engine: 1977-8? 360 bored .030 Kb pistons 10.5 to 1 Crank turned .010 bottom end balanced. Comp Hyd cam and lifters 510 lift. Eddy alum heads untouched. Stock rockers. Eddy torker intake with Holley 700. MP electronic ignition. TTI headers Powermaster starter.
Trans: 727 reverse manual valve body. 3K stall convertor
Rear end: 8 3/4 Moser spool with 35 spline axles. Yukon gears 4:30 Green bearings
Suspension: Front- stock rebuilt with rebuilt manual steering box, drag shocks, 6 cyl bars. Rear- s/s springs moved in 3", drag shocks
8 gal fuel cell with frame mounted Holley pump
10" manual brakes front and rear all new
Body is clean with my first attempt at a paint job. Single stage with trim holes filled. Passenger inner fender was cut but I have a rust free replacement.
Have US Body fiberglass hood and scoop goes with car as well all parts I've gather for car.
Car is in Ashland , MA
Have title. $6000.00 Firm for car with parts.
I'm sure I'm forgetting things. PM with questions. Pictures in next post.
Drag racing season is here!!!
And I owe taxes must sell!!!
I know times are tough so price drop!!!!
$5500.00
