[WANTED] '64 Dart Tail lights
The Moffittman
Asheville
Hi all, I'm looking for a set of driver's quality tail light lenses. I paid $1500 for the car, I'd appreciate it if the price you're asking was around or less than 5 percent of that.. For some reason, 64 Dart tail lots seem to bringing a mint.. There's ten sets of '61 Dart taillights for under $100 on eBay right now.. The last set of '64s went for over $200. Help?
A tip - if you find some '64 Dart taillights for less because they're missing the inner and/or outer Chrome trim, you can order replacements for those from Layson's. They also have re-pop taillights. Not sure any of that gets you close to your 5% of $2200 goal, but...
Thanks, both of my current units are missing the inner chrome trim. I need to replace the passenger side light, because it's cracked from 2 o'clock to 9 o'clock around the outside of the center section. Since both are hazy, and missing inner trim rings, I figured I'd need a matching pair to keep the same aesthetic across both sides. I'll look into Layson's, but I still suspect that known good units from you helpful folks will be cheaper than new versions.. Right? Right? ::crickets chirp::
Also, not to pick nits, but looking for the $100 or less mark, not the extravagant 5% of $2200 mark.. (Isn't math hilarious?)
