[Found!] 64 Valiant arm rest base
RustyRatRod
Caput villa stultus
Georgia
I need a passenger's side arm rest base for a 64 Valiant 2 door sedan. Red. Must not be cracked around the screw holes. Thanks.
64 Valiants used two lengths of front arm rests. What is the length you need? The base for the 10.5 inch pad is common (especially on two doors) but some came with the base for the 9 inch pad up front. Are you looking for a red plastic base or chrome type base with red pad?
My bases are red. So do I need to measure the pad or the base?
Either. Just need to know if its the long one or the short one. I'll check my bases tomorrow. I don't remember how many red ones I have.
The base measures 10" right were it meets the door. The pad is about 8 3/4" long.
Well I've got a red,short base but someone painted the exterior army surplus aluminum. I've got it soaking in Superclean to see how it comes out. Will let you know as soon as I see if it will come clean.
Here are pictures of what I have
Like I said don't know if left or right.
