1970valiant
young gun
225 slant six, that is rebuilt with about 1k miles on it. Comp cam, hydraulic valve train, Docs medium volume oil pump, ported/polished intake ports, mallory hyfire ignition, aussispeed long runner 4bbl intake, edlebrock carb, and ceramic coated dutra duels.
The steering is tight and has a Frim feel 16:1 ratio steering box. Rebuilt Kelsey Hayes 4 piston calipers with new rotors, pads, bearings, hoses, and studs. KYB shocks. All front end bushings have been replaced. 904 push button tranny with a transgo shift kit, the tranny shifts great but has a big leak from the torque converter seal and the pan gasket. Aftermarket stereo, 90amp alternator, mini starter, champion aluminum radiator made for a sbm, electric fan, new fuel sender, fuel tank has been cleaned out and resealed, interior is in good condition. the rear seat has been reupholstered but the front seats are in rough condition. the car has some rust in the rear quarter panels/wheel wells, drivers side door, and the paint is ruff. All the trim is there. Good Hankook tires. 7.25 rear. I have new and extra parts to go with car duel master cyl, proportioning valve, extra fuel pump, sb 904, eta.. Tags good till 2020.
Needs a longer throttle cable to be drive able.
Located in peoria az. $6,500.
