[FOR SALE] 640 HP bigblock
mcat
cincinnati ohio 45251
i am selling the entire drive train out of my 70 cuda its a indy headed 493c.i. roller motor,(640hp) eagle rotating assemby built at BES racing,(3700lbs car ran 10.60s) every mechanical part that makes this car move is for sale.. from aluminum radiator, to new 727 with new coan 8 inch converter and Turbo action transbrake. the cheetah shifter, the HOLLEY 950 carb. the uni-lite distributer., the msd box, the meizer electric water pump,and electric fan go.the alternater, and the coated 2-1/4 step ceramic coated headers, and 3 inch exhaust, go... an E-BODY K-frame with wilwood disc brakes, go. all front suspension with drag shocks and manual steering box. go... wanting 10,500 for everything.. serious inquiries only please.. this is everything to make you E-BODY a legit 10 sec. BB car... the trans. converter and brake are new with no runs the engine has less than 100 passes it is all perfect and ready to go... still in the car running and driving. you can hear and see it run.. i will seperate
