[FOR SALE] '65 273 engine
moper
eastern CT
Complete carb to oil pan. Turns by hand. Does not include accessory brackets or pulleys. Manifolds are B body. Engine is out of B body and was described to me as able to run although it's grungy inside. Currently the carb is stuck and needs a rebuild. $300
I also can provide any amount of machining or assembly up to a complete dyno'd engine package, or any body or mechanical repair, restoration, or tuning of your Mopar.
I'll have to get it for you Prob not today but I'll post them as soon as I grab them.
OK - had a minute to go look.
On the block, under the Driver's head is stamped "A-273 4-24"
Casting date is 3-8-65.
Hopr that helps - I've never been much of a numbers guy but the casting date tells me it was a late production assembly/car. Assembled in Aprill-ish, and in a car before the June shutdown.
