[SOLD] '65 273 Exh. Man. #2465769
Richard Sweet
Ventura, CA
I'm looking for an exhaust manifold with casting #2465769. It's for a '65 Dodge window van, with a 273, V8. The left and right sides are both center dump, but I need the one without the heat control valve.
Thanks, Richard, Ventura, CA
The left and right side manifolds are interchangable. I want to replace the right side with a left side manifold without the heat control valve. If I can't find one, I might have to use a right side manifold and remove the heat control valve and plug the shaft hole.
My old one is cracked and warped and has been over torqued, so I have to replace it.
Please send me a private message if you have one in good shape and I'll give you my email address so you can send some pictures and we can discuss price.
Thanks, Richard, Ventura, CA 93003.
