waggin
moving on ain't easy if you drive a Ford :p
13 to 1 compression W-2 heads .030 340 strip dominator tunnel ram with dual 660 holley center squirters, 727 auto with reverse manual valve body and 4500 stall convertor hooked to 8 3/4 rear dual gm calipers on each rear wheel one for foot brake per wheel and one for steering brakes (for when you are on a wheelie) all lights, turn signals and even the back up lamps work, most of the body work is done but the car needs to be finished, clear title, this is a true formula S car that was too rough to restore but too solid to not save....will consider trade for Nice newer truck, must be extra cab or four door with cold a/c 15,000 Cash Car is located in floral city florida 34436
