[WANTED] 65 Barracuda Front Wheel Hub
If it's 9" you need, I have a pair, complete with backing plates, brakes and spindles. Not interested in separating.
This is exactly what I need. I’m pretty new to using forums, how do we move forward from here?
What is exactly what you need? Just a bare 9" hub? 9" Hub and drum assembly? Spindle too? The hub itself is the same on both sides. The wheel studs came in LH and RH versions, but, you can convert to all RH if you wish.
I just need the hub itself, but having the drum assembly wouldn’t hurt to have as well
