65' Barracuda Strut Rod Bushing Confusion
JeffreyLee
1965 Barracuda
meridian Id
I am just starting to re-assemble my front end components after purchasing a front end rebuild kit from PST. Everything is coming together just like it came apart except the bushing that PST provided for the strut....
As you can see, the original rubber bushings don't look anything like the PST replacement pictured in the background. Even the 66' service manual shows the big bushings and washers that look like what was on the car originally. I'm not sure how to position the PST bushing (which side points to the front of the car), or what types of washers and nuts to use. The groove in the PST bushing looks like it corresponds to the opening on the car's frame. Do I just lubricate the PST bushing and force it through the hole? How do I tighten this arrangement up with washers etc?
Should I try to source the original bushing parts from another supplier? Thanks in advance...
The one PST sent you is what is called the one piece and the other type obviously the two piece.
Those one piece ones work, but they sure are a pain in the a** to install compared to the two piece.
If it were my car (and it was when I did mine) I threw those in a box and got the two piece.
Check this thread out.
proper way to install these strut rod bushings
