best done with 2 people. remove the chrome trim at the base of the glass. Pull lock strip, carefully remove the aluminum corners at the base, they are delicate. As mentioned, use a wood or plastic tool to break the seal of the gasket to the glass- spend a few extra quality minutes doing this. with one person on the inside, start with one upper corner and gently push it out at about a 45 degree angle, and as it begins to come loose, slowly add more pressure inching along to the center. when a space develops that can be held by the 2nd person, they can begin gently lifting it. once the entire top is separated, the inside person can get out, and together both tilt the upper half out at the 45 degree angle holding both sides. it will get very easy now as it is just removing the sides, but as you you get close to the bottom, slow down and then try to slide the glass up and out of the bottom. Ther gasket can be resused if it is in good shape, but there are repops available.
Take your time, as these are big and while easily found, not easily shipped or transported.
