twistthethro twistthethrottle Joined Feb 1, 2015 Messages 97 Reaction score 43 Location south carolina May 30, 2016 #1 the sway bar on my 65 measures a hair under 13/16th, would that be considered the 7/8th sway bar?
65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 13,707 Reaction score 4,545 Location Strasburg, VA May 30, 2016 #2 That sounds about right
twistthethro twistthethrottle Joined Feb 1, 2015 Messages 97 Reaction score 43 Location south carolina May 30, 2016 #3 awesome thanks, I'm ordering the front end kit from P-S-T and wanted to make sure I get the right swaybar bushings
65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 13,707 Reaction score 4,545 Location Strasburg, VA May 30, 2016 #4 Roger that! I believe you have to cut the weld on the bracket to remove/install the new bushing and then close the bracket back up and re-weld.
emsvitil Well-Known Member Joined Mar 14, 2015 Messages 887 Reaction score 1,142 Location SoCal May 30, 2016 #5 Under 13/16 would be closer to a 3/4
