CMKirk
Hello!
Finally got the A833 swap in my '65 Dart DONE a week or so ago. Took it for the inaugural ride...and the shifter jams/hangs up on the 2-3 shift about every 3rd time.
I was aware that I might have issues when I got the shifter...it had internal rust and thick coat of dust/dirt, but it seemed to shift fine when I tested it out of the car. I sprayed it down with PBlaster and then oil, but no dice. Jam city.
The shifter is a Hurst factory shifter (Comp Plus, IIRC) that has an integral shift lever. Please correct me if I'm wrong...I haven't pulled it back out yet.
I've already checked out a number of "how to rebuild your Hurst shifter" vids, and it doesn't seem that hard.
Is there a specific rebuild kit for the factory/OEM Hurst shifter as opposed to an aftermarket shifter? I'd don't want to waste time, effort, and expense with the wrong kit
If I decided to go new instead, what Hurst shifter and lever would I have to use on the A833 in an A body?
Thanks...
Chris
Thanks...
Chris
