65 Dart GT - automatic transmission fluid level
65AggieGT
Member
Houston
Son drove home from college today and said the transmission had been shifting strangely the past few weeks. I warmed up the car put in neutral and checked the fluid. It was low.
I added about 20 ounces of ATF, drove it around for a few minutes, back into neutral. Son checked it this time and level was at the "add 1 pint" mark. He added a pint (16 oz.) of ATF, drove it around, back into neutral, checked again. Still showing to be at the "add 1 pint" mark.
While wanting this to be teaching moment, also don't want to over-fill the transmission, not sure how much more it needs before it hits the full mark. Please advise.
Hot while in neutral and then fill accordingly. That low would explain what was going on.
Jake
Engine warmed up in NEUTRAL , emergency brake engauged , run through the gears a few times . Let tranny settle down a little . Pull dipstick and wipe off . Return dipstick and pull and read . Wipe off and do again 2 more times to verify reading . If you have to put that much fluid there you have a major leak , imo .
Thanks all for the input. Ended adding another 21 ounces before it registered full. Did it gradually. No leaks showing up yet. I'm sure we'll figure out the problem before spring. Right now, its running great.
