904 Shifting issues
Wayne Miller
1962 Dodge Lancer Wagon
Barrie Ontario Canada
I have a 1962 Dodge Lancer with a pushbutton 904.
Slant 6 engine
Transmission has been rebuilt.
Stock cooler in the bottom of the rad.
Tranny filter is clean and fluid level is correct.
Today i drove the car 80 miles no problem. Stopped several times and the trans shifted as expected. Started off from stop close to home and it shifted through 1,2 and 3, short distance down the road it was just like i took the gear shift lever ( if it had one) and shifted into neutral.
This has happened several times.
Any help would be appreciated.
Most likely cable adjustment. Probably cable is adjusted on the borderline of N & D.
