65 Dart- Motor Swap /6-V8
haole
USA
Can I install a small block without changing the steering link or will I need a drop link center?
most will tell you that you need the drop link but in my case (64 with /6 to 360 swap) i raised the motor instead. put 3/8" pieces of steel plate under the motor mounts with holes for bolts and it got me plenty of clearance over the steering link.
-Tim
Thanks for the good info.........................
