65 Dart Power Brake assembly
sgrip65
66 Dart GT 273, 65 Dart GT 273 HiPo
Minnesota
Members. I have a Power Brake booster that I bought from another member. In my dis-assembly, I failed to note which direction a part would go in the re-assembly. Could anyone help me out? Enclosed are some pics of what I am speaking of. This part goes between the booster and the Master Cylinder. As the pics show, there is some sort of filter element within this part. I did attempt to find a diagram online, but that diagram seems to be unavailable....at least I could not find it. Does this filter go toward the PB booster or toward the Master Cylinder. Thanks for the help. sgrip65
Towards booster. Also make sure the pushrod that goes into the M/C is adjusted per the factory service manual before installing. It makes a difference as far as compensation ports being exposed properly etc. and will lead to issues with the brake system operation if it’s off too far. I don’t have my manual readily available to give specifics.
Here’s a how to article. Not positive the .020” is 100% correct but it’s sounds familiar.
Got A Soft Brake Pedal? Don't Forget The Booster Pin to Master Cylinder Gap
And another
https://www.jegs.com/InstallationInstructions/500/555/555-631010-116.pdf
And another
Thanks Dubob. I appreciate the advice and the links. sgrip65
