65 Dart window sweep replacement
If the inner door panels are off, adjust the down stops so the glass can be rolled down farther then normal.
Then use a plastic spatula/putty knife and put it between the door frame and the sweep / cat wiskers.
Pry the putty knife away from the door frame a little bit. As mentioned before use needle nose pliers and pull mostly straight up.
